Capture an image of the same size as the object
I’m trying to make a captured image without margin about select object.
(Same size of bounding box. bmp/png whatever.)
Like picture below…
Is there any good idea?
And… Could anyone explain how to use SetOffset of ViewCaptureSetting?
I’m using c#, and Rhino7.
Thanks in advance.
See if this example helps.
Thank you soooo much!!
The posted codes exactly what I was looking for.
I had to add the ZoomExtentsParallelBorder setting… :sweat_smile:
