I have a problem with the Brep-method CapPlanarHoles(). I am lofting three circles and then caping them with the CapPlanarHoles. However, it does not only cap the planar holes but also adds a surface on the side. Attached a picture of what it looks like. Do anyone know why this happens? When I do the capping with the GH-node or use the NodeInCode I do not have that issue (however, then get other issues as NodeInCode returns Object instead of Brep).
My code is:
List<Brep> breps = new List<Brep>();
var tempBreps = Brep.CreateFromLoft(_circles, Point3d.Unset, Point3d.Unset, LoftType.Straight, false);
foreach (var brep in tempBreps)
breps.Add(brep);
for (int i = 0; i < breps.Count; i++)
brep[i] = breps[i].CapPlanarHoles(0.001);
It’s part of a VS-project so I’ve cut out the parts with the lofts into a C#-node. So, now I’ve attached the GH-file - sorry if the adaption got a bit messy - @dale I would really appreciate it if you would have a look.
