Cap Holes Curved Hex Grid
Hi all,
I have a hexagonal core between two curved surfaces. I want to export the file as a volume in step format such as each extruded hexagon is individually selectable.
I tried with cap holes ex but strange lines appear, as shown
Curved Beam Hexagons_CapHoles.gh (11.4 KB)
I tried to project the hexagons on the surfaces but I can’t obtain a closed final volume to export as with cap holes.
Curved Beam Hexagons_Projection.gh (20.2 KB)
Do you have any suggestions? How to use cap hole in my case. Thank you very much :slight_smile:
Depends what you do with that step file:
a) Either extruded and cap hex mesh outlines
b) Split offseted surfaces with hex cell exstrusion and joint them.
Due to discretization the b option must has larger surface than cells to have the correct split.
Mesh.gh (37.1 KB)
Curved Beam Hexagons_CapHoles.gh (18.4 KB)
Here’s one way
