I use the same script in normal Grasshopper work very well, but when I use it on Revit the script can not work, the main issue is when I use cap holes to make close brep the brep will has strange line and I can not use evaluate curve.
It’s happened sometimes when I updated my Revit from 2020 to 2023 It’s becoming better, but I totally can’t use it today.
I think it is a system issue.
I tried to restart Revit and rhino and update the software those ways all failed.
someone can help me ???
So, I checked it through revit and seems to be working fine on my side, using RiR v.1.10.83~ , so maybe try the latest daily build or release candidates and recheck… else maybe someone else can have a look and help you more.
Also, would be good in the future if you can filter data inside your definition with only geometry having issue to make it simple to check instead of sending the full definition
Hi, can anyone help me to simplify my script? for example what component can instead list item and evaluate curve? hence list item is not a very accurate component to select item and sometimes item will change…
thank you guys…
Hi Japhy one issue is when I use cap holes the top surface like the image shows u the surface only shows part of the surface and I fix it when I restart the Revit many times.
Basically, I just use list item to select and evaluate curves to make walls and door frames.
