I can’t zoom when a certain object is selected.
This happens regularly, and now I have an example to work with.
Load the file and do not change the view.
2026-07-21_CantZoom.3dm (135.9 KB)
Select the object by left click, then try the mousewheel zoom.
Or CTRL+RMB, or PgUp/PgDn.
This is also in V8.
I can zoom when the gumball is off.
Deleted most of your geometry and added two named views…
2026-07-21_CantZoom_9.3dm (103.4 KB)
Aha, I didn’t realize the Gumball is on…
Nevertheless Zoom is expected to work even if the Gumball is active.
There is definitely something wrong (=bug).
This is not cosmetics only.
Gijs
(Gijs de Zwart)
4
thanks @Charles
RH-97100 Can’t zoom when Gumball is active
The effect is also there in a viewport where no Gumball is:
@Joshua_Kennedy
brian
(Brian Gillespie)
6
RH-97002 is fixed in Rhino BETA
