Can't View Coincident Points in Detail Views with Section active
Using the divide command on a line coincident with the section line, the resulting points aren’t visible until the section is deactivated.
Hi @djhg,
Please, could you provide an example of this?
Here’s a video
Can’t View Coincident Points in Detail Views with Section active
Hi @djhg,
I have been testing it and it works:
Section
Please, could you send me your file? I’ll try to reproduce it with yours.
My files are big and my days are long, so I can’t always make time to zip or simplify my large projects, but so far I haven’t had a project where this isn’t an issue…
Hi @djhg,
Which Rhino and VisualARQ versions are you using? Just in case I used a different one to reproduce the issue.
Rhino and Va have been current, though I haven’t yet installed yesterday’s rhino update.
