When chaining edges (for example when selecting edges for a rail sweep) there are two problems:
- the dialog that asks which of several possible curves you want to choose keeps moving down the screen as each one is chosen - presumably it would fall off the screen if there were enough picks (!) [there used to be a similar problem with the text edit popup dialog some years ago in v3 or early 4 ]
- you cant use the view commands to adjust the view of the model while in this mode, which makes the command useless on a model where you need to be able to zoom into it or pan it to actually see what curve you need to choose.
Cheers
Rabbit
