I’m using Add Component by location to place columns in a Revit model. I can adjust the base and top offset but I get an error when I try to change the levels that base and top are set to. I get the following error. Any suggestions would be greatly appreciated.
“1. RhinoInside.Revit.GH: Failed to assign an element from a diferent document.
Parameter name: Base Level”
p.s. I can’t use the curve based column component because I need to see the alignment of the columns using planes… unless there is someway to rotate the columns after they are placed…?
