if i would like:
⌘R for ! _-RunPythonScript script1
⌘F for ! _-RunPythonScript script2
it wont accept both… the second one replaces the first one instead of accompanying it.
i think this is good in most cases since it helps you avoid making duplicate shortcuts. (though you can still assign 1 shortcut to two commands… which should probably get sorted out eventually)
but in a case like running a script, it should let you make separate shortcuts if the trailing name is different.
In the latest RhinoWIP, it seems you can run different scripts from different keyboard shortcuts. @jeff_hammond you might want to sanity-check our work…
