Hello there,
My problem is that I can’t choose the whole edge of my geometry which has already broken into pieces. Also, merge edge commands didn’t help me. Here, I am describing my problem better with an image.
Hello there,
Hi -
I’m afraid there’s little we can do with an image. Please post the 3dm file.
brokenpieces.3dm (441.7 KB)
Hello, Wim
Here is the model and an additional image,
Initially I removed the bottom surface of blue plate to get the exact intersection surface of the golden rail, below it.
Thanks.
Hi -
Use ExtractSrf
to extract the two surfaces that make up the bottom of that blue plate and delete those.
Use Cap
on the blue plate to create a closed polysurface.
Use MergeAllEdges
to merge the edges.
NOTE: it appears that you are using a very old version of Rhino 6. Please update to the latest service release.
