Hi, so I’m not sure if i accidentally typed some command but i now cannot select any text using my mouse (either by clicking, using a right window or a left window). I can still select texts by the seltext and selectall function, or if its in a group or block, clicking on the text will still select the group/block. I’ve checked my layers and also my selection filter and both are fine. If anyone could help that would be great! Thank you!
Same. Another forum discusses this issue. Just happened to me. my Selectionfilter has annotations. My graphics card is updated. It’s not locked or anything. How to fix?
Selecting everything else and then inverting seems to help. run bounding box when you get the text selected via invert and it prompts text to be selected again. Then delete the bounding box. Fixed.
