Can't select obejcts with transparent Materials
I come across this often and it must be a bug or oversight. If I have any kind of object that has a semi transparent material applied even only 25%, Rhino won’t select it in rendered or my custom view modes. I have to switch either to wireframe mode or shaded mode then the object selects. Also many times snapping won’t work in some of those modes if ends or mids are occluded forcing me into wireframe mode. Why are you making selection and sometimes snapping dependent on a material’s transparency or view mode? Not a good thing.
RM
