steps:
- After opening a Floating viewport, things felt odd [3DConnexion wasn’t working on the floating VP] and It showed as active both it, and the VP on the main rhino window.
- So I closed the Floating VP,
- at this point I couldn’t select anything in the rhino VP.
- i selected some geometry via the layer panel.
- Now I can not de-select the selected stuff. [can de-select by locking the layer]
- everything function ok Only running command won’t work [it is possible to type commands but they won’t run.
- escape does nothing
- I can’t save, but if i go via manu and try to save, it opens the save window, but it won’t save.
I’m on Version 8 (8.17.25063.13002, 2025-03-04)
I can add the most recent Syst-Info But I’ll have to force quit rhino first to do that and perhaps loose some stuff on the unsaved file.
[Here’s the last SysInfo I have on file , note the current installed version above.]
Syst_Info_akash_21Feb25.txt (13.4 KB)
thanks a lot
