I understand that after trial expiration you can use but can’t save.
When I try to open ver7 it says “no license” and then i just get stuck in an endless loop entering my license key (trial key) and some bizarre convoluted hoops to jump through and it say “closing rhino”. What happened to the run with no save ability?
You didn’t say, but I’ll guess your expired evaluation license is in your login account.
Remove the license from your Personal licenses using this URL:
Then start your Rhino and use the option to use the license stand-alone on that one computer.
Then Rhino will run indefinitely without Save/Export.
It looks like it was removed some time ago.
Look in your email messages from December 2020.
That’s when you requested it.
That old message will have the expired V7 license key in it.
When you start Rhino without a license you should see this:
Enter your email address, agree to the EULA, and press Continue.
You should see this
Click the little Options link in the bottom left corner, and click Enter License Key.
Enter your expired V7 eval key and follow the instructions to lock it to this one computer.
ok, so i made some progress (my pop-ups look nothing like the ones you just posted you must be on Win 12) It looks like you can’t eval. Rhino7 on multiple machines with the zoo license only on one computer, correct?
Ok, I had to figure this out the hard way! FYI you cannot have multiple evaluation versions of Rhino7 running on different machines! You have to release the license from one machine in order to use it on another. Now I know!
