Can't run Python script example
I tried to run the ExportPoints.py example and get this error.
Message: ‘file’ object has no attribute ‘writeline’
Thanks Mark
This is an error in translating the script over from vb. There is no “writeline” method in Python.
The section should probably look like this:
 for id in objectIds:
#process point clouds
if( rs.IsPointCloud(id) ):
    points = rs.PointCloudPoints(id)
    for pt in points:
        file.write(str(pt)+"\n")
elif( rs.IsPoint(id) ):
    point = rs.PointCoordinates(id)
    file.write(str(point)+"\n")
The “\n” will put a newline after each point string written. The only problem there is that there will also be a new line at the end of the file - there are workarounds for that if it matters…
HTH, --Mitch
Thanks Mitch
Not something I was missing then.
Mark.
