With Rhino running, opening another instance from the executable causes the current instance to shutdown without warning. There is no prompt to save work.
I am also using MatrixGold 3.1 and Rhino will not open any files with MatrixGold running. It will get to the splashscreen and then disappear.
MatrixGold isn’t running when I start another instance of Rhino from the executable for the existing instance to shutdown without warning. Is this a common behaviour or Rhino?
No, you can normally run multiple instances of Rhino concurrently without problem.
If you open one instance of Rhino and run the Systeminfo command from the Rhino command line, then copy and paste the output into this thread, you will give us a starting point from which to analyse what is going on.
Windows 11 (10.0.22621 SR0.0) or greater (Physical RAM: 32Gb)
Primary display and OpenGL: NVIDIA GeForce RTX 3080 Ti Laptop GPU (NVidia) Memory: 16GB, Driver date: 8-2-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 517.00
Secondary graphics devices.
Intel(R) Iris(R) Xe Graphics (Intel) Memory: 1GB, Driver date: 5-31-2022 (M-D-Y).
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 8-2-2022
Driver Version: 31.0.15.1700
Z-Buffer depth: 24 bits
Total Video Memory: 16 GB
C:\Program Files\Gemvision\MatrixGold\MatrixGoldPlugin\MatrixGoldPlugin.rhp “MatrixGoldPlugin” 3.1.22284.1001
C:\Users\44753\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\NVIDIADenoiser\0.4.3\NVIDIADenoiser.Windows.rhp “NVIDIADenoiser.Windows” 0.4.3.0
Menno! You’re a life saver. Disabling the MatrixGold plugin seems to have done the trick. Opening multiple of Rhino and MatrixGold from executables, from files, with no issues! Thank you!
