My block manager window width is stuck at around 2000 pixels and I cannot make it any narrower! I can still make it wider, but not any narrower. I’ve had this issue for a while now…
Why is this a thing? Anyone else having this issue?
Rhino for Mac
Version 6 (6.29.20239.15172, 2020-08-26)
Well… I really don’t know what happened, but my block manager resizing started working right after I posted this topic Thanks for tip though! I actually did try to search something like that to fix the issue.
However, I can’t reduce the width of the block manager if there is a lot of names in the “Used by” field under “Properties”. For example if you have 100 different blocks that uses “Block 01”, the block manager width will explode if you selected “Block 01” from the list and view its properties. Is there a reason why “Used by” field has to force show all the block names in single line until there is no desktop / screen width left? I actually believe that my original issue is someway related to this bug.
