Hi I am trying to make a negative of a model head to cut from a 5 axis CNC router, but in preparing the file I cannot split this box into four quadrants. I don’t understand why, as I was able to meshboolean split the modeled head from the mesh box I created around it… perhaps self intersections or small triangles.
Hi - the mesh tools haven’t been Rhino’s strongest side and are being worked on for Rhino 7.
Perhaps you could try to split the head from 4 quadrant boxes instead of trying to split the one box into 4 after the boolean operation? If you post the model, maybe someone might have more tips…
Our current mesh intersector doesn’t like situations very much where triangles have very different sizes. When you reduced the mesh, perhaps the new triangles were a bit more of the same size where they intersected.
Another thing you could try if you run into this again, is using a voxel-based plugin (like Dendro or Crystallon) to do the boolean split.
