Hi there. I’m having trouble getting the patch command to work on this surface. Also tried Curve network with no success. Any input would be much appreciated. This project is for an air filter mask for Docters and nurses treating Covid19 patients.
Surface patch should only be used when all else fails. I can’t open your file so I did my best to approximate it. You can get a good result with blends and trims.
Hey Pascal, wondering how you created this. The dark blue and pink surfaces look like they could be 2rail sweeps? Which tool did you use to create the gray surface I have selected?
Hi Joel - All three surfaces are lofts. Some have been ‘noodled’ at the point level quite a bit, as well as subjected to ChangeDegree and InsertKnot and MatchSrf. As you suggest, Sweeps might also do fine here - I did not try it - I tend to make sweeps second choice, because they often make fairly dense surfaces right off the bat, and I prefer to have more control of that.
I’ll try to make a blow by blow file if I can in a bit - but the main thing I wanted to suggest was the layout of the surfaces - getting four-sided surfaces to work in that awkward shape.
Nice, Stratosfear, what tool did you use to create that middle section? Is that a blendsrf? Any details on that would be helpful. I’ve been having trouble getting surfaces to match up smoothly, without having a small crease left over from where the surfaces come together. Thanks.
I’d just use surface blend. Tangency for the pipe form, make sure to position the surface seam on the outside. So the trim doesn’t cut across it. Then Curvature for the trim blend. Then surface match Tangency to the flange ends.
