Using below:
BETA
(6.1.17312.221, 2017/11/08)
Beta
Using the check for update says I’m using the latest BETA.
I may have installed the latest on another pc which I don’t have access at the moment.
Using below:
BETA
Beta
Latest BETA is (6.0.17325.16351, 21.11.2017). Did you press the Check Now… link/button on the check for updates -page?
I hit the check for update and browser opens but says it’s the latest.
I could go open the link from the release update thread, but I need to go through all the
serial number entering…
@nathanletwory,
The latest PUBLIC beta is 6.0.17325.08311
The latest available daily is 6.0.17325.16351
(both are 2017-11-21)
Checking daily, gives same results. Rhino is up-to-date.
I wonder if it has something with installing to multiple pcs…
Installed directly from link to the dowload. Thanks!
Ah, you got accidently a 6.1 build. You should uninstall this very Rhino, and install another 6.0 build. There was a few hours or days that those accidently ended up in the 6.0 update stream.
Got it. Thanks. will uninstall it first.
I was wondering since I was able to select cylces render
