yafimski
(Yafimski)
January 18, 2021, 10:54am
1
I’m trying to install the latest version of Lunchbox for Rhino 6 from food4rhino .
I’ve downloaded the latest versions that should work.
When I run the installer I get the error message :
I had some previous non-working Lunchbox install in my Programs on Windows, so I removed that and it still doesn’t work.
Is there a .dll or registry issue I need to fix in order for this to work?
Would appreciate if anyone has dealt with this issue in the past and knows the solution.
Thanks
wim
(Wim Dekeyser)
January 18, 2021, 2:13pm
2
Hi -
Have you tried downloading and installing it with the TestPackageManager
command in Rhino 6?
yafimski
(Yafimski)
January 18, 2021, 4:14pm
3
Hi, thanks.
Interesting, but it just says it’s downloading… forever. It doesn’t actually download.
wim
(Wim Dekeyser)
January 19, 2021, 2:20pm
4
Hi again -
It appears that the 2020.6.30.1 version doesn’t work on Rhino 6. If you pick the 2020.6.30.0
version from the dropdown in that dialog box, things should work…
yafimski
(Yafimski)
January 19, 2021, 2:39pm
5
Thanks.
Of course I’ve tried that before posting… it’s the same result.
wim
(Wim Dekeyser)
January 19, 2021, 2:42pm
6
Hi -
Please run the Rhino SystemInfo
command and copy-paste the result here.
yafimski
(Yafimski)
January 19, 2021, 3:01pm
7
Thanks.
I’ve hidden private data but the info is below.
Doesn’t seem unusual though…
Rhino 6 SR19 2019-10-22 (Rhino 6, 6.19.19295.01001, Git hash:master @
00000000000000000000000000000000000000)
License type: Commercial, build 2019-10-22
License details: Cloud Zoo. In use by: yafimski
Windows 10.0 SR0.0 or greater (Physical RAM: 16Gb)
Machine name: XXXXXX-XXXXXXXX
Non-hybrid graphics.
Primary display and OpenGL: NVIDIA GeForce GTX 1060 with Max-Q Design (NVidia) Memory: 6GB, Driver date: 11-6-2019 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 441.20
Secondary graphics devices.
Intel(R) HD Graphics 630 (Intel) Memory: 1GB, Driver date: 2-28-2018 (M-D-Y).
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 11-6-2019
Driver Version: 26.21.14.4120
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
Rhino plugins
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.19.19295.1001
C:\Installations\Grasshopper Plugins\Elefront\elefront421\ElefrontProperties.rhp “ElefrontProperties” 1.0.0.0
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.19.19295.1001
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.19.19295.1001
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.19.19295.1001
wim
(Wim Dekeyser)
January 19, 2021, 5:14pm
8
Hi -
I’m afraid it does.
yafimski:
Rhino 6 SR19
The current version is Rhino 6 SR33. Please update your installation.
