Can't input wall layers thiner than 0.02 meters
Hi is there a Way to Input a layer thiner than 0.02 meters ? If i go under 0.02 the layer extends at the end .
Hi @Daniel_Stahl check the Absolute tolerance of your Unit settings (in the Document Properties > Units). You should have a value that is at least 0.001 meters.
@fsalla Tank you ! Absolute Tolerance and Display precision solved the problem
