Hi I’m trying to use rhinocommon instead of runscript and I have no idea what I’m doing here. This is what I got but what do I fill in the …?
Dim element As Rhino.DocObjects.ObjRef() = Nothing
Dim element2 = Rhino.Input.RhinoGet.GetMultipleObjects("Select splitting objects", False, DocObjects.ObjectType.Surface, element)
If element2 <> Rhino.Commands.Result.Success Then
Return element2
End If
doc.Objects.UnselectAll()
Dim curve As Rhino.DocObjects.ObjRef = Nothing
Dim curve2 = Rhino.Input.RhinoGet.GetOneObject("Select curve", False, DocObjects.ObjectType.Curve, curve)
If curve2 <> Rhino.Commands.Result.Success Then
Return curve2
End If
Dim test2 = curve.Curve
Dim test = element(0).Geometry.Transform(Split(test2))
It appears you are trying to split a surface with curve. RhinoCommon does not have a function that will do this. So, you can try to extrude the curve through the surface and then split the surface with the extruded surface. Or, you can script the Split command.
Yes I found out the last way whith rhinoscipt Now I want to delete the 2 outer parts and I will try to do this with extruding the curve and check if the surface that needs to be deleted is inside the extruded surface or not. This is possible right?
Guess not. Just have to figure out how to check if the srf is outside of the crv
Dim go = New Rhino.Input.Custom.GetObject()
go.SetCommandPrompt("Select closed surface or polysurface")
go.GeometryFilter = Rhino.DocObjects.ObjectType.Surface Or Rhino.DocObjects.ObjectType.Brep
go.GeometryAttributeFilter = Rhino.Input.Custom.GeometryAttributeFilter.ClosedSurface Or Rhino.Input.Custom.GeometryAttributeFilter.ClosedPolysrf
go.Get()
If go.CommandResult() <> Result.Success Then
Return go.CommandResult()
End If
Dim brep As Rhino.Geometry.Brep = go.Object(0).Brep
If brep Is Nothing Then
Return Result.Failure
End If
RhinoApp.RunScript("_selnone -_selname elementL", False)
Dim refs As Rhino.DocObjects.ObjRef() = Nothing
Dim rc As Result = Rhino.Input.RhinoGet.GetMultipleObjects("Select srf to trim", False, DocObjects.ObjectType.Surface, refs)
If rc <> Result.Success Then
Return rc
End If
Dim tol As Double = doc.ModelAbsoluteTolerance
'voor elk punt in ptsel doe: check of deze in ptsel zit anders verwijder het punt
For Each ref As Rhino.DocObjects.ObjRef In refs
If pt IsNot Nothing Then
pt.Trim(brep, tol)
End If
Next
But tbh. I have no idea what to fill in interval U/V and what that means. So. A tip would be nice please.
Well I guess I just have to try a bit longer before asking xD All figured out now. Thanks anyways Sorry for asking before trying enough xD
