I lost my block edit window as well. I can’t exit the block without it, so i have to shut down rhino 6 to get out. Unfortunately, I can’t ever edit any blocks that I’ve made since I can’t find a way to get my block edit window back. Anyone know if there is an “exit block” command? Anyone know how I can get the block edit window to show up again? I can’t work at all without this. Thanks!
Hello - please try running testResetWindowPositions
. (type or copy/paste the whole command)
Any luck?
@JohnM - do you have an idea?
Thanks for responding. I tried it twice, but nothing. All the windows I had docked on the right side went away (I had Properties, Layers, etc), but the block edit window is still missing. Is there anything under the Panels tab that I need to check to get hte window back?
Unlock gets me out of block edit mode, but I am unable to edit any blocks after that, so I’m not sure it’s working properly either. I’m able to modify orphan geometry, though.
Please run SystemInfo
and post the result here.
Does the issue happen with any block or a particular file only?
Does block edit work if you create a new model, make a block and try to edit it? If so could you send me a model where it does not work and I can take a look at it.
I tried creating a new file and running Block edit on that. Same Issues. I could get into block edit mode, but the window won’t pop up. When i unlock all, I don’t think i get completely out of Block edit mode, because even though I could modify regular geo, running the Block edit command wouldn’t let me select blocks. ??? I finally uninstalled Rhino and reinstalled and now the block edit window comes back. thank you!
Hi guys, thanks for all the good info, just so happened to come up with a “hack” to get back the window if you don’t want to, or cannot “unlock”;
So, we all agree that the “Block Edit” dialog window seems to disappear at random moments during work in progress. for me, its as soon as I click on screen, however…
If you click on your taskbar (for PC - if you run mac you have bigger problems anyways that your probably working on jk), open a web browser or another program and click your task bar icon for the web browser, opening a browser window, then click back on the Rhino icon in your task bar. Do this once or a couple times and your “Block Edit” dialog window is bound to show up!
Ah Rhino, we love you. Hope this helps!
Hi Everyone, I just had this same problem and I found a solution to the problem.
If you have the block edit window, press Add Object. You will be able to add all of your lines and geometry that is not in the block. Press enter or OK, All of the geometry will be added to the only available block but now you can explode that block and you will have all of your geometry.
I find that it is best to just copy and paste the block into an entirely new project browser and save it separately. Although it doesn’t completely solve the problem, it will save you hours or days of work.
Hi - as I understand it, this thread is about a situation where that dialog window is not visible.
Could you describe the problem that you are trying to solve?
Also, please run the Rhino SystemInfo
command and paste the result here.
I had this same problem - just type ‘unlock’ < this will solve the problem
Thank you for the ‘unlock’ suggestion and the others who provided alternatives. It helped!
I am having this issue in Rhino 6 current version. I had locked objects in my block, so when I typed unlock they unlock. After that, unlock has no effect and my Blockedit window remains gone. OTher suggested remedies above have no effect.
The issue began when the Blockedit window refused to respond, with all options greyed out. There was no command active, and I could not close block edit, so I pressed the x button and the window disappeared and I am stuck in Blockedit. Saving and closing… But it just opens in the same unusable condition.
My fix in such a situation is to open the unusable file, copy the most current items from the open block, and paste them into the most recently saved version (because it appears the programme won’t autosave when it’s editing a block., is that correct?)
Closing Block Edit window (with X button) with adding or removing an object command active may be part of a sequence of commands which created this.
Happened again. I’m working on a project which is a polar array of one block, so I’m in the block frequently. I think it might have to do with undoing also.
This is ongoing, and it can be debilitating. It happens to me every couple of weeks.
The unlock command explodes the block as edited, and leaves the block in some abbreviated form.
If the edit to a block is significant and time consuming, a lot of work can be lost.
The latest wrinkle is that the major element from the block which got exploded out of it by the unlock command will not respond to the add to block command.
Hello - do you not get a warning box when you do this? It should, and does here (6&7) block me from closing the editor while in the process of adding or removing objects…
Yes. So I guess it’s not that. But somehow the Block control box disappears but block editing is still open with no way to stop it short of “unlock”.
This is still an issue on Rhino 6 (current build). I think undoing actions involving or within a block editing session might trigger it.
I’ve never had this happen before, but just did; I suppose I also closed the block edit window in an attempt to exit block editing w/o saving…perhaps ctrl-z a few times confused Rh. Shouldn’t there be a command to ‘exit bedit’ or something?? Or shouldn’t closing the block editor window just exit block editing?? Totally stuck. Closing & reopening didn’t help.
