HI , I am learning Kangaroo 2 and i am using a set of definitons released by Daniel Piker.
one of the excercise does have a component that i cannot find inside current Kangaroo2. I find a similar component that uses same icon but the one show below is like a ghost.
does anyone know where i can find it ?
thanks
This component is obsolete, you can always find any obsolete component by doing the usual double click type search on the canvas but use “#” first.
thanks a lot Mahdiyhar,
point is that i was making the search without “#” and the result was only the curve collide (CC) component
the Collide2d comes out on the search only by using “#” and i didnt know i could finest the search by doing this
i was also trying to use the “CTRL”+“ALT” search option but the “Collide2d” is like a ghost and its position is not shown. do you know if there is a phisycal location or is it a hidden component ?
thanks
Ivan
Hi @cloudsvisitor77
See this post:
Need kangaroo's CurvePointCollide to affect both point and curve
Thanks for pointing this out, I’ll make sure the example file is updated.
