Can't export stl
Hi, I did fillet edge on this penguin and I can’t seem to fix all the naked edges. Can some explain or tell me how to fix this? Thanks, SusanJAN 16 SHUGHES PENGUIN.3dm (2.9 MB)
you need to make some changes on the input curve to have a bigger radius:
also try to avoid situations like this. that could lead to non-manifold edges which is not good for printing
you can use Addknot to add some points to have more control to adjust the shape:
before:
After:
then it works as usual:
Diego–Thank you so much for your feedback. --Susan
