I keep having this error… "…/zlib.lib is not a valid Win32 application. What’s going on?
Well, you are correct, zlib.lib
is not a Win32 application. I’m assuming you’ve downloaded the openNURBS toolkit and have build it using Visual Studio? What exactly are you trying to do?
– Dale
I’m trying to run the examples_read.cpp. I feel that I don’t know how to run it. I read that I had to compile and run, but that message from before keeps appearing. What do I have to do?
Well, if you just want to run example_read.exe
, just navigate to the output folder, open a Windows command prompt, and run the .exe.
If you want to debug the application in Visual Studio, then right click on the example_read
project, in Solution Explorer, and pick Set as StartUp Project
. Then press F5.
– Dale
