Hello!
As the title says. I created a vaElement, Grasshopper style, and the delete menu entry in the Element styles dialog is greyed out.
Bug or feature?
Thanks!
Hi Eugen, object styles can’t be deleted in two situations:
- There is an object in the model using that style.
- That style is the “current” style. That means that it is the last style inserted and the one that is pre-selected when inserting an object. Just insert an object with a different style to make it the new current style, and therefore be able to delete the other one.
Thank you, will check it out!
