Can't cut/split/trim object
Hi everyone!
I’ve generated this solid and want to trim it’s edges (whatever is outside this boundary box). As you can see, I can find the intersection between the two, but I can’t find a way to separate them. I’ve tried Solid Intersection, Trim Solid and Split Brep, or it doesn’t work or my computer crashes.
Any ideas on how I can do this?
Thanks in advance.
PORIFERA.gh (22.2 KB)
PORIFERA.3dm (132.7 KB)
You may give it a try with Dendro, and fyi.
Dendro | Food4Rhino
PORIFERA.gh (29.4 KB)
You may try to make the branches longer than the box so the intersection would find the cutting point easier then using solid intersection it should work.
Of course Dendron is a more reliable solution all because you can grow the complexity without affecting the speed so much, with solid operation time waste is linear to the number of branches.
Hi! Thank you so much for your answer! Your file made me realise I had installed the Dendro plug-in incorrectly. After I installed it correctly, it worked like a charm! So again thanks!
