Like the title says, I’m getting an object reference error when I try to grab the Rhino viewport’s plane and use that to create a 3D View in Revit. Does anyone know what is going on here? It is creating a 3D view from this even though it is throwing up an error, however every time it’s the same view that isn’t aligned to the plane I am giving it. I’m trying to use my Rhino Named views to create corresponding Revit Views. Here’s a screenshot of what I’m doing:
Edit: It seems that it is creating it with some connection to the plane that I am giving it although it appears to need some sort of transformation to get the two views to align.
Edit2: Just found this: Add 3d View Fails · Issue #292 · mcneel/rhino.inside-revit · GitHub Any timeframe on fixing this? @eirannejad Also, I don’t know if it is related, but the Rhino view/Gh Plane and the Revit view don’t match, is that all the same issue?
