I made a script that divides a curve into a class,returns a list of points and connects this list of points with another list and so on.My problem is that it works correctly when all the things happens inside the class.But when I make instances and try to take the list of points outside the class and connect the points ,then I have a problem.Any thoughts?
connecting_eval_lines.py (1.9 KB)
Hi Liano,
You set your “flist” out of the class. In this way both instances end up with the same points returned from your “curveattractor” method. That is why you can’t make a line (points coincide).
Set your “flist” as local under your “curveattractor” method.
connecting_eval_lines.py (2.0 KB)
thank you!
