Cant boolean, how to cut shape out of sub d's
Hi, id like to cut the difference out of the bottom beam. however when i run boolean it turns the objects into rounded shapes because they are subd’s i assume. , i want to keep the objects sharp not round.. i read booleaning will mess with the polys and thats why they go round. how would i go about cutting out the difference in the button beam? i tried ‘insertpoints’ but that was very fustrating and didnt lead anywhere. thanks.
Hi @Taylor7
I think you are getting a few concepts confused here. First of all: Are those beams sub-d’s? If yes: Why? Sub-d is great for complicated, organic shapes, but not very suitable for things like beams and hard edges. I think you’d be much better off doing this in plain Nurbs. And since you are seeing them turn into “rounded shapes”, I suspect you might either be in box mode, which shows the control polygon of the sud-d’s (sort of like a simplified representation, making it easier to see the flow of the topology) or have hard-creased all the edges. Try pressing tab to turn box mode on and/or off.
Second, there is no boolean tools for sub-d’s. If you insist on using sub-d for this, you’ll have to add points and edges to your topology and line it up with where the beams intersect, and then move/delete/add faces accordingly.
If they are indeed sub-d’s, they will be converted to Nurbs when you boolean, which is probably what you are seeing when they turn into “round shapes”. The boolean operation turns them from sub-d box mode to Nurbs, revealing their true form. And as always, it would be much easier to help, if you posted a 3dm file rather than a screen grab, which is really hard to trouble shoot.
HTH, Jakob
to add to what Jakob said, you can save what you have by extracting control polygon and then making these parts a mesh.
you can then use mesh to nurbs to convert them to simple polysurfaces, then use mergeallcoplanarfaces to unify them into useable nurbs geomerty that you can then boolean.
unrelated but fwiw, this workflow works amazing if you scan a room with the irhino room scanner…
