I’ve just discovered a problem with file access in Rhino 8 for Mac. I was creating annotation styles, and I was saving them using “save as template”, but when I would try to retrieve them through “import” in annotation styles they were nowhere to be found. I couldn’t find the templates anywhere on my computer, except when I would open rhino, and I would choose from the template I could see the templates I created there. When I write clicked on one of the templates I created, then clicked “show in Finder” The templates would appear, but there was no path associated with them in finder. I was able to find the path by hovering over the file and holding the option key. However, when I would search the path, I could go as far as “Application support” and from there the “McNeel” file was nowhere to be found. It’s odd that it’s missing but the workaround that I found was to create a templates folder and store the templates there, which I would save in the usual manner, and that way I’m able to access my templates when changing the annotation settings, the same way I would as if I could use the native “save as template”.
I found a workaround instead of using the move command or gumball move. Ordinate responds to the gumball copy (move w/ Gumball + tap Option), so you simply copy the points that define the kink and then delete the input.
Looks like the post above wss intended for a different thread.
To get to these template files via “Finder” you have to make “hidden” files visible. Use Shift+Command+.(=full stop)
Then follow (user name)_Library_Application Support_McNeel_Rhinoceros_Template files
Max.
Any luck?
