Hi Guys, I don’t know if this is the correct forum to post this problem, but I am doing it just in case. I also sent an email to the Rhino tech support team.
During my trial version of Rhino 6 I installed some Grasshopper plugins at the usual, file->Special Folders -> Components Folder. But as soon as I got my educational licence, I cant access any more the Components Folder in Grasshopper. When I click the icon, the folder never pops up ( I also tried the other folders and nothing happens also) I have tried re-installing Rhino again, but I still have the same problem. Also, the plugins that I previously installed during my trial version keep appearing even though I have uninstalled Rhino. I don’t know why this is happening, but its very strange
Any help would be great
Thanks!
Nicholas
The folder it opens is inside %appdata%\Grasshopper\
, is that still there?
Hi David,
thanks for your reply, yes through the regular Appdata path, it can still be accessed, but not from the grasshopper canvas. Maybe its a small bug with the Rhino 6 educational License, that’s why I decided to report it to see if it has happened to anyone else.
Nicholas
I doubt it has anything to do with Rhino. That menu item just tells Windows “run this folder path as a command” and then it opens in Explorer
(or File Viewer
I think it’s called now in Win10).
It could be that your new Rhino installation doesn’t have the rights to execute a command like that. You could try starting Rhino in administrator mode, see if that makes a difference.
It still does not work, but since you say its not a problem with Rhino itself, I guess it does not matter .
Thank you!
Nicholas
