Cannot use temporary/oneshot object snaps (solved)
Hello, noob question here.
When I try to use oneshot osnaps by holding shift or altgr and hovering over the osnap bar the buttons turn grey. When I try to click one of them nothing happens and the oneshop osnap does not trigger. The same thing happens when holding ctrl to use refrence osnaps such as along parallel.
a recording of the issue here:
Thanks in advance.
Hello- the one shots only activate if Rhino is inside a command when a n xyz location is needed.
Thank you for the quick reply!
