At the time LSCM was chosen as the unwrapping algorithm ABF was also evaluated but it only worked on simply connected meshes.
A logged request for implementing ABF: https://mcneel.myjetbrains.com/youtrack/issue/RH-42693
@D-W I filed also a bug for the actual unwrap issue: https://mcneel.myjetbrains.com/youtrack/issue/RH-42696
It’s repeatable in both 5.14 and 6.0 BETA.
The polysurface is closed but its render mesh has 24 naked edges. I tested @clement’s first macro and it reduces naked edges in render mesh to 12. It’s possible that unwrapper has problems tracking the selected seams on the mesh because of these naked edges. I will investigate this further later. Generally naked edges in a render mesh often indicate that polysurface may need some fixing - for example rebuilding edges or re-parameterizing surfaces.
