Cannot select split surface
How can I select and remove the cut out holes and select the surrounding spit surface? List index and cull index don’t seem to work. I’m pretty sure I have to do something to the data, but not sure what.
split surface.gh (216.7 KB)
Thanks,
Omar
Thank you, that worked for selecting the cut surface. But now how can I select the actual cut out pieces? I tried using the same logic but it didn’t work.
Cull reversed A list with index 0
Thanks I realized I had forgotten to put the correct index. Thanks again.
