Every time I try to save a custom toolbar, I get an error window
I’ve tried Save, SaveAs, changing the name
Hi Jake - can you please run SystemInfo
in Rhino and copy/paste the results here?
Rhino 7 SR16 2022-3-8 (Rhino 7, 7.16.22067.13001, Git hash:master @ aa7902c94c5aa33511e60d30f82b636be43bc85f)
License type: Commercial, build 2022-03-08
License details: Cloud Zoo
Windows 10.0.19043 SR0.0 or greater (Physical RAM: 16Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce GTX 1660 SUPER (NVidia) Memory: 6GB, Driver date: 11-22-2020 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 457.51
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 11-22-2020
Driver Version: 27.21.14.5751
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
C:\Users\trim5\source\repos\WPF_ReactiveUI_TestCase\bin\Debug\net48\WPF_ReactiveUI_TestCase.rhp “WPF_ReactiveUI_TestCase” 1.0.0.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.16.22067.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.16.22067.13001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.16.22067.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.16.22067.13001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.16.22067.13001
Hi Jake - what happens if you disable
in Options > Plug-ins page, close and reopen Rhino?
Same error after disabling the mentioned plugin.
I’m attempting to add a menu item under the File menu item. I noticed something else:
When I simply add new toolbars or groups to the toolbar, it saves with no error.
When I add the custom menu item to the File menu, it throws the error when I save
The custom menu item is just a named menu item with a macro.
Hi Jake - can you please send the rui file to tech@mcneel.com with a link back here in your comments?
Sent. Thanks for your help.
Hi Jake -thanks, I see that error as well. I’ll investigate…
@jakemurphy0118 - as far as I can see this is just broken -
RH-67926 Toolbar: RUI save fails with menu item
It seems adding to the File menu is the bad thing - I can add to other menus.
Jake: As a side note, when I looked through your system info I noticed your Nvidia driver is from 11/22/20. It’s probably time to update just to keep the driver up with your R7 version.
This is mine:
Primary OpenGL: NVIDIA GeForce GTX 860M (NVidia) Memory: 4GB, Driver date: 7-30-2018 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 398.82
If it ain’t broken, don’t try to fix it…
If it’s working for you it’s kind of hard to argue.
On the other hand, while I know that @jeff et al are doing great work in keeping Rhino capable of working with older cards and drivers, I also know that openGL capabilities improve over the years and believe later versions of Rhino include features that use use some of those capabilities directly rather than through workarounds and my belief is that those features perform better that way.
So I have always believed that it’s a good idea to keep the drivers up-to-date and to upgrade video cards as often as economically practical (in my case every 5 years or so). Am I living in a fool’s paradise?
OpenGL, like anything else, comes in versions.
The drivers I’m running tell Rhino they are supporting version 4.6.0.
Rhino targets features that are available in OpenGL 4.5.
Lots (and lots) of drivers have bugs. OpenGL features that they should be supported aren’t as they should. Driver updates fix bugs. Rhino updates try to work around known bugs in many drivers.
If you come across a driver that isn’t showing issues, stick to it.
RH-67926 is fixed in Rhino 7 Service Release 17 Release Candidate
