In the wonderful world of Rhino’s huge array of commands it is easy to forget stuff…
… I’m pretty sure that there is a command for this, and was illustrated in a V4 remote control tutorial that I watched about three years ago. If you look at the image attached, you’ve got several parallel or semi parallel lines and you want closed curves (loops) to run through them. The red curves in my illustration were generated with interpolate curve but are not vertical. I believe that the command I am thinking of will keep all the curves that touch all the lines vertical – almost like cutting sections through them. You can then use those curves (loops) to loft between them.
Anyone remembers this?
