Cannot print with white color, always show some grayish
Hello, I’m confused for my floor color, I’m putting display as white, priting as white but always print as grayish. What should I do?
Hi Pvc-
It’s very hard to diagnose an issue from an image.
If you use hatches, they will be white.
If these are surfaces and you are using the default shaded display mode, there will always be interaction with the light source in the scene, causing white to be gray. You could modify this display mode and set the “Lighting method” to “Scene lighting” instead of the default “Custom lighting”.
Many thanks, your option really make my polysurface floor become white (which represent white paper). But it does create another problem, which is now print color not working anymore, instead when print it becomes display color. I attached my file so can you please take a look. My road surface and retaining wall become some what kind of gradient, I need to make them constant color.
Hi Pvc-
It seems like you forgot to do so.
File it is quite large, I tricked it to no lighting. But by the way, I can not set printing black box (polysurface), do you know how to fix it?
Hi Pvc-
I’m afraid I don’t know what that means.
