I’ve made a case model in Rhino8, exported as stp file then sent it to manufacture, In there they can’t measure the size of beveled rectangle hole. As picture below. Solidworks just doesn’t recognize the arc. Is there any method to fix this? Another file format maybe?
Not sure if this answer still arrives in time, otherwise for future use:
If the surfaces that form the hole are merged into one surface (which appears to be the case, looking at the screenshot) SolidWorks will not be able to turn this into a hole with rounded corners.
Can you advise how you created the holes?
If the shapes are actual lines and arcs, this command will split the surface into its parts:
_DivideAlongCreases SplitAtTangents=yes
