I’m completely stuck. I’m getting the following error:
- Solution exception:Cannot marshal ‘parameter #5’: Invalid managed/unmanaged type combination (Arrays can only be marshaled as LPArray, ByValArray, or SafeArray).
when using Cocoon’s refine function and Yellow’s smooth function. I found this post at the old grasshopper forum and, following @DanielPiker 's advice, I updated my .NET framework and made sure plankton was up to date and operational. None of this worked. Does anyone have any suggestions?
I’m running Rhino 5 on Windows 7. I do have Rhino 6 installed but am using 5 for the moment because my computer is garbage.
