Hi I have disc and key but only goes to a small icon on bottom task bar says C:\users\shaun\apdata\local\temp\7zsc786.tmp\english\startup…cfg and does nothing further…
Help Please!!! Anybody
@shaun.smuts Try downloading the installer from here, https://www.rhino3d.com/download/rhino/4.0/release.
Does that work?
Hi Vanessa
It does exactly the same gets to the same point and stops
My Machine is running windows 10
Hi @shaun.smuts - Something to keep in mind is that V4 was developed long before Windows 10 came out, so even once installed, you might run into issues. Just a disclaimer ;-)…
Now, to try and get V4 installed, if you have an optical drive on your computer, insert the V4 CD > browse to the Rhino_setup.msi file. Otherwise, you can unzip the V4 installer file you downloaded from our site and browse to the same Rhino_setup.msi file. This file should get Rhino 4 installed on your system.
