Make sure you are debugging in a Debug build configuration. The RhinoCommon plug-in wizard creates two debug configurations: Debug32 and Debug64, with the only difference being the external program it starts when debugging.
Also, our Debug build configuration project settings should look similar to this:
I have a similar configuration in project settings, the is: Active(debug 64). please have a look the images attached.
Packing is the rhino plugin command and packinginterface is a project in WPF. When the plug-in is executed, the wpf window is called, the data is processed and son on. Then I use rhino to display the geometry. the code works well. The big problem is I cannot inspect the classes and variables. Because VS community 2015 close Rhino every time I try to inspect a variable.
Since the project it not so big right now, I will creates a new rhino project and an new wpf to test everything again.
I also open a threat in VS forum.
In VS forum suggested the error comes from the Rhino template. My “feeling” is the error comes from a conflict in the git, nevertheless I can’t explained and/or proved.
I restart a new Rhino project and a new WPF window. And so far is working and I can inspect the variables.
