I would like to create a plane with hexagonal cells all over it, but only a small part of it is covered with the hexagonal cells. Does anyone know what is happening?
modeling the complex roof of Center Pompidou metz.3dm (147.5 KB)
center pompidou.gh (13.1 KB)
a Plane parameter contains a list of planes (not planar surfaces: infinite planes)
if you make your Surface (scale β Output G) pass through a Plane parameter, it will extract the plane on which your surfasce lies (if itβs planar)
you might want to use a Surface parameter, or just connect your scale G output directly to the Hexagons Cells component :
Thank you so much! it works!
