Cancel Transformation
Is there a way to cancel a transformation during execution?
I stupidly used the gumball to shift an architectural plan, including text annotations, and it is slowly shifting each piece. Its been processing for the last 10 minutes; I’ve tried the esc key but no success; anyone know a way to cancel/stop the operation?
Thanks.
I’m not aware of any functionality but have you tried turning on alerter?
I haven’t tested it in your situation, just because I prefer to kill rhino.exe process than waiting.
Thanks for this @tay.othman, Alerter looks like it can run a Rhino command (_cancel maybe?) which could be what I’m after, haven’t tested it yet though…
Give at try, It may work, and let me know how it works.
Hu Luke - can you please run SystemInfo in Rhino and copy/paste the results here?
Hey @pascal, unfortunately I cannot recreate it. It’s only happened a few times before, usually when exporting DXFs for some reason ~ if it does happen again I’ll copy the debugging info here.
Thanks
