German language version:
Results in:
-C-H-A-R-L-E-S-
Hi Charles - thanks, I’ll see what I can find out - works OK here in English.
Looks like MoveUVN is the culprit, it’s not getting "_Hide"
https://mcneel.myjetbrains.com/youtrack/issue/RH-38693
That noted though, I am not sure “Cancel All” needs to deal with MoveUVN in V6, since it is a dockable panel. What do you think?
thanks,
Hi Pascal,
While we are at the panel, some controls are too small, they cut the text:
I also note a good thing:
Scrolling in this panel is ok.
Thanks,
-C-H-A-R-L-E-S-
RH-38693 is fixed in the latest WIP
Hello Pascal,
in WIP (6.0.17129.11351, 09.05.2017) it is now even worse.
To retrace:
Open the MoveUVN panel, and drag it by the grabbing the tab to the other panels.
Cancel all by right click on the arrow icon.
Guess what:
Cancel removed the panel.
I can’t imagine this is intended, or?
Charles
Hi Charles - yeah, thanks, I have it on my list to review what this macro does.
Hello Joachim,
I think it has to do with the applied DPI in Windows.
This are my standard settings:
Mine are these: text size 100%, horizontal orientation & resolution 1920x1080 (on Windos 10). My screen is a Dell S2316H.
My suggestion is to give it a try changing your configs.
No, I won’t.
Rhino has to run at 125% and all other %.
Or?
In my case, it certainly does:
(Haven’t tried bigger than 125%, of course.)
Hmm, I can’t tell for sure, but it seems the Windows scaling kicked in in your case.
All the text in the Rhino UI is blurred, or?
If that is the case, Rhino runs on 100% and is scaled by pixels.
Also (I can’t read the red Spanish text), you need to restart the PC.
Can you try again after a restart?
Yes. On Monday morning.
Then, have a good weekend ![]()
Do you see it now after the reboot?
