It automatically spins 90 degrees the moment the part ornament hangs over the wall. Can I fix this?
The 90 degree corner window is not positioned and rotates.
The Slavic steps from archline xp are invisibly called in. Can it be modified?
TEST.3dm (3.8 MB)
Corner window is not being processed. Please check and correct it.
Hi @user2166 There are no corner windows in VisualARQ (they are planned for future versions). So the only way to them right now is to insert two windows, one on each wall, and subtract the remaining part of wall between both with the vaSubtractSolids command, using an auxiliary solid of subtraction.
What do you mean?
