Can you select groups from the Rhino model
I’m trying to move all the Rhino model elements (some were exported from Revit with a survey point) closer to 0,0,0. I’m thinking it might be more consistent doing this using Grasshopper than moving everything manually. The issue I found is that you cant add the groups to Geometry or Groups node from grasshopper.
Is it possible to select groups from the Rhino model?
Thanks,
Human plugin has a group id output
