Can You print in Raytraced mode ?
When I try to print to pdf in Raytraced mode I get a blank page. When I try to print to a desktop printer I just get a thin line.
Thank you, Andy
Thank you, Andy
Not directly with the Print command, no.
Instead, after your Raytraced display has “cooked” long enough that you like it, use the ViewCaptureToFile or ViewCaptureToClipboard command to save the image in it’s current state. Then you can print it however you want.
Any luck?
Yes; this worked. Thank you John.
